[Qgis-user] QGIS - Sextante
    Mark Stevenson
    M.Stevenson at massey.ac.nz
    Tue May  8 16:42:19 PDT 2012
Thanks for the quick reply Salvatore!
I've checked the folder C:\Users\Mark\sextante\ and have the following
files and folders:
grass [folder]
tempdata [folder]
grass_script.bat
saga_batch_job.bat
sextante.gisrc
sextante.history
sextante.log
sextante_qgis.conf
sextante_qgis.log
sextante_script.r
It seems the R code to run the function is getting written to
'sextante_script.r' whereas the program is expecting to find the code in
'sextante_script.r.Rout'.
When I change the name of the existing 'sextante_script.r' to
'sextante_script.r.Rout' the function works but when go to do another
analysis the R code gets written to 'sextante_script.r' again.
Mark S
On 9/05/2012 11:00 a.m., Salvatore Larosa wrote:
> Il giorno mer, 09/05/2012 alle 09.49 +1200, Mark Stevenson ha scritto:
>> G'day folks,
>> I'm hoping someone can help me.
>> I'm running QGIS 1.8.0-Lisboa on a Windows 7 machine and have installed
>> version 1.0.5 of the Sextante plugin.
>> I also have R version (i386 version 2.15.0) and all of the usual spatial
>> packages (rgdal, maptools, spdep) installed in "C:\Program
>> Files\R\R-2.15.0". The binary directory for R is "C:\Program
>> Files\R\R-2.15.0\bin\i386".
>> Under options and configurations in Sextante I have:
>> "C:\Program Files\R\R-2.15.0\bin\i386" set as the R folder and
>> "C:\Users\Mark\.qgis\python\plugins\sextante\r\scripts" set as the R
>> scripts folder.
>> When I load a polygon and point vector files into QGIS and run one of
>> the example R scripts from Sextante (for example, Ripley's K function) I
>> get the following error:
>> [Erno2] No such file or directory:
>> 'C:\\Users\\Mark\\sextante\\sextante_script.r.R.out"
>> Any ideas on what could be wrong?
> Check in folder C:\Users\Mark\sextante\ if you have something like!
> it should be *.r.Rout and not  *.r.R.out
> Regards,
> -SL
