[Qgis-user] QGIS - Sextante
Victor Olaya volayaf at gmail.com
Tue May 8 23:21:40 PDT 2012
The file created by SEXTANTE is sextante.script.r, and taht is
executed by R using R CMD BATCH
The Rout file is created by R to save its output (is like a log file),
and R does not expect any code in this file, since it is R itself who
creates it
Which version of SEXTANTE are you using? I have just tested it with
1.0.5 and it seems to work fine...
Regards
2012/5/9 Mark Stevenson <M.Stevenson at massey.ac.nz>:
> Thanks for the quick reply Salvatore!
> I've checked the folder C:\Users\Mark\sextante\ and have the following files
> and folders:
> grass [folder]
> tempdata [folder]
> grass_script.bat
> saga_batch_job.bat
> sextante.gisrc
> sextante.history
> sextante.log
> sextante_qgis.conf
> sextante_qgis.log
> sextante_script.r
> It seems the R code to run the function is getting written to
> 'sextante_script.r' whereas the program is expecting to find the code in
> 'sextante_script.r.Rout'.
> When I change the name of the existing 'sextante_script.r' to
> 'sextante_script.r.Rout' the function works but when go to do another
> analysis the R code gets written to 'sextante_script.r' again.
> Mark S
> On 9/05/2012 11:00 a.m., Salvatore Larosa wrote:
>> Il giorno mer, 09/05/2012 alle 09.49 +1200, Mark Stevenson ha scritto:
>>> G'day folks,
>>> I'm hoping someone can help me.
>>> I'm running QGIS 1.8.0-Lisboa on a Windows 7 machine and have installed
>>> version 1.0.5 of the Sextante plugin.
>>> I also have R version (i386 version 2.15.0) and all of the usual spatial
>>> packages (rgdal, maptools, spdep) installed in "C:\Program
>>> Files\R\R-2.15.0". The binary directory for R is "C:\Program
>>> Files\R\R-2.15.0\bin\i386".
>>> Under options and configurations in Sextante I have:
>>> "C:\Program Files\R\R-2.15.0\bin\i386" set as the R folder and
>>> "C:\Users\Mark\.qgis\python\plugins\sextante\r\scripts" set as the R
>>> scripts folder.
>>> When I load a polygon and point vector files into QGIS and run one of
>>> the example R scripts from Sextante (for example, Ripley's K function) I
>>> get the following error:
>>> [Erno2] No such file or directory:
>>> 'C:\\Users\\Mark\\sextante\\sextante_script.r.R.out"
>>> Any ideas on what could be wrong?
>> Check in folder C:\Users\Mark\sextante\ if you have something like!
>> it should be *.r.Rout and not  *.r.R.out
>> Regards,
>> -SL
> Qgis-user mailing list
