[Qgis-user] QGIS - Sextante
M.Stevenson at massey.ac.nz
Wed May 9 05:03:21 PDT 2012
Yes, when I run R CMD BATCH on sextante_script.r from a DOS box I get the
correct results written to sextante_script.r.Rout and a (correct) PNG file
is written to C:\Users\Mark\sextante\tempdata.
The contents of sextante_script.r for this 'test' problem is as follows:
library("rgdal")
points = readOGR("D:/Temp/BH_village-wgs84.shp",layer="BH_village-wgs84")
png("C:/Users/Mark/sextante/tempdata/1336564408.941.html.png")
library("maptools")
library("spatstat")
ppp=as(as(points, "SpatialPoints"),"ppp")
plot(envelope(ppp, Kest, nsim=100))
dev.off()
Mark S
>> I can start a DOS box and enter:
>> R CMD BATCH C:\\Users\\Mark\\sextante\\sextante_script.r
> When you do that, does R create the Rout file?
> It seems thar R is not creating it, but SEXTANTE expects it to be
> created always. I will add some check, so in case the R does not
> generate that file (I assumed that it was always generated...maybe it
> is created somewhere else...), it does not throw an exception and
> crashes
>> [even though I've upgraded to Sextante 1.0.5 the menu option
>> /ANALYSIS/ABOUT SEXTANTE still tells me I'm on version 1.0.4. When
>> Sextante has loaded the menu option for Sextante has changed from
>> 'Sextante' to 'Analysis' however.]
> My fault. I forgot to change that :-) If you downloaded 1.05, I can
> tell you you are using it :)
