[Qgis-user] Re: Sextante plugin works except with GRASS
Victor Olaya volayaf at gmail.com
Wed May 9 05:45:08 PDT 2012
I have fixed the first bug and improved the definition of
v.surf.spline, so it should work now
It is on the SVN (r176) already. Please test it
Thanks!
2012/5/9 Pietro Rossin <pierigis at gmail.com>:
> Here I am again
> the above python error occurs when I select "show table-like parameter
> panels" in sextante general option.
> When unchecked this option the error doesn't occur, but..
> I tryied to interpolate my point values with v.surf.bspline.
> Again the "unable to load output" error occur with logs in the attached
> file.
> http://osgeo-org.1560.n6.nabble.com/file/n4962705/v.surf.bspline.Log.txt
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4962705.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
