[Qgis-user] Re: OSGB coordinates to WGS84 lat/lon problem
Nick Hopton nhopton at gmail.com
Thu May 10 12:04:28 PDT 2012
Andy Harfoot wrote
> Have you tried the convertor here:
> http://gps.ordnancesurvey.co.uk/convert.asp
> to see whether the higher accuracy coordinates obtained from QGIS match
> those obtained using OSTN02?
For the record, the Survey gives the following (ETRS89) lat/lon coordinates
for the points:
Inkpen: 51.3524757 -1.4650872
Hodmore: 51.4984893 -1.0170283
Hindhead: 51.1154179 -0.7157938
I think ETRS89 has drifted about half a metre away from WGS84 at the present
time, but even so the transformations done by Lisboa under Ubuntu look very
good.
> It looks as though Proj4 can use grid based transformations like OSTN02
> through the use of gsb files. Could it be that this is the case in the
> higher accuracy situation? I find gsb files at the following location on
> my Win7 QGIS 1.7.4 install:
> C:\OSGeo4W\share\proj
At present by default QGIS doesn't use a grid-shift file for EPSG:27700. The
datum-shift is carried out by the +towgs84 part of the Proj parameter
string.
> I can't see any files in this directory suggesting they are the OSTN02
> grid though, and I can reproduce your 'Vista' results as follows,
> suggesting that my QGIS is using the lower accuracy seven parameter
> transform.
It's not using a grid-shift file. But it's interesting that you get the same
poor transformations that I get with 1.7.4 under Visa. Lisboa RC1 under
Ubuntu produces much better transformations (for me) but I don't know why
this is the case.
Nick.
View this message in context: http://osgeo-org.1560.n6.nabble.com/OSGB-coordinates-to-WGS84-lat-lon-problem-tp4965339p4966416.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
