[Qgis-user] Running QGIS on Debian testing
Nicklas Avén
nicklas.aven at jordogskog.no
Fri May 11 04:51:39 PDT 2012
Hallo Örjan
Compiling from source is quite easy because of the list of dependencies
in the doc:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/master/entry/INSTALL
The list for sid or squeeze should need very little editing (if any)
I use to also compile gdal, geos, proj4 and PostGIS to get the trunk
versions.
HTH
Nicklas
On Fri, 2012-05-11 at 13:34 +0200, Örjan Wennbom wrote:
> Hello list,
> I noticed that the qgis package is not currently available in Debian
> testing. I have tried the various alternative sources listed on the
> qgis homepage with varying results.
> The gfoss.it squeeze packages work, but without Python support. They
> depend on python<2.7. I manually edited this dependency to the python2.6
> package instead so it would install, but it still does not work for
> some reason I have yet to investigate.
> The qgis.org packages (sid and wheezy nightly) and the package in
> the Debian sid repo all Crash with the following error:
> qgis.bin: /build/buildd-sip4_4.13.2-1-amd64-oTGNAQ/sip4-4.13.2/siplib/siplib.c:10938:
> sipEnumType_alloc: Assertion `(((currentType)->td_flags & 0x0007) ==
> 0x0003)' failed.
> Aborted
> I am running an up-to date Debian testing (wheezy) on an amd64
> platform. I would greatly appreciate any pointers to what my next
> step toward a working QGIS install should be.
> Regards,
> Örjan
> Qgis-user mailing list
