[Qgis-user] geocoding
Ezra Boyd
eboyd3 at tigers.lsu.edu
Mon May 14 09:22:51 PDT 2012
Hi Mike,
Google Fuzion Tables makes this very easy (at least for the U.S.)
First you upload the your list of addresses into Google Doc's, then
you open it up as a Fuzion Table. Then under the Visualize tool,
select Map. This will display your points in a Google Maps like
environment. It also lets you download and save the points as a .kml
file (which you can open in QGIS).
It has been a while since I have done this, so I don't know how it has
changed with the new Google Drive.
Hope it helps!
Ezra
On Mon, May 14, 2012 at 10:51 AM, M.E.Dodd <m.e.dodd at open.ac.uk> wrote:
> Thanks for the suggestion. I thought this was possible in qgis just from a
> list of addresses (within limits on numbers of matches per day) but perhaps
> not. Currently I am trying http://www.gpsvisualizer.com/geocoder/ however
> with yahoo to match against the results are of rather limited use. Most of
> the addresses are actually in uk but come back as showing in usa, perhaps I
> need to add country name. a bit more worrying is exact same address shown
> up in different places and giving different coordinate pairs a number of
> miles apart. There is also a limit of 1000 addresses.
> From: QGIS [mailto:qgis at dandittmann.org]
> Sent: 14 May 2012 16:21
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] geocoding
> On 05/14/2012 08:35 AM, M.E.Dodd wrote:
> Is it possible to geocode a list of addresses? I have the geocoding plugin
> loaded and it works (api key sorted out) but not sure how to get the list of
> addresses into qgis as they have no x,y location info at the moment. Am
> sure this question asked before but could not find the answer.
> Dr Mike Dodd
> Department of Environment, Earth and Ecosystems
> The Open University
> Walton Hall
> Milton Keynes
> MK7 6AA
> http://www.ispot.org.uk/
> http://www.floodplainmeadows.org.uk/
> I am aware of two potential solutions:
> 1) Locate a webservice and have that produce the Latitude/Longitude
> coordinate pairs.
> This site has several:
> https://webgis.usc.edu/Services/Geocode/About/GeocoderList.aspx
> Most as far as I can tell do not have support outside the United States
> however.
> Ultimately it would be a nice feature to have added to the plugin.
> 2) The solution I had to go with was to use PostGIS outside of QGIS to
> generate the Latitude/Longitude pairs. This may not work depending on your
> setup, available time, knowledge level, budget, or level of access within
> your organization.
> The available documentation I found assumes that United States Census Bureau
> data is used to geocode against. This solution could be made to work for
> other countries if the same/similar type of data released by the US Census
> Bureau is made available by the locality for which you wish to geocode for.
> Changes likely will be needed either to the setup scripts or the final
> database columns prior to loading data from your locality to take into
> account differences between how things are done in the US versus your
> locality. Examples might include length and data type of postal codes and
> state/provincial abbreviations.
> Some information can be found here:
> http://postgis.refractions.net/documentation/manual-svn/Geocode.html
> A setup guide
> http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data
> Dan Dittmann
> The Open University is incorporated by Royal Charter (RC 000391), an exempt
> charity in England & Wales and a charity registered in Scotland (SC 038302).
> Qgis-user mailing list
