[Qgis-user] Postgis query performance
fork
forkandwait at gmail.com
Mon May 14 12:01:25 PDT 2012
Hi all,
I am running Master, trying to query a postgis layer via the attribute table
(Tiger blocks for the state of WA). It takes many, many minutes to finish, but
when I run a similar query in psql it takes 4.830 ms
psql query: select geoid10 from block10
where cityname10 = 'Wenatchee' and gq10 >= 10 order by geoid10;
layer query criteria "cityname10 = 'Wenatchee' and gq10 >= 10"
Is there a way to speed this up?
Also, when I run the "query" from the right-click menu, and choose test, it
gives me the number of rows without a select criteria (the above criteria should
yield about 10 rows, but test says ~174000)
Any ideas?
Thanks!
