[Qgis-user] Re: Postgis query performance
fork forkandwait at gmail.com
Mon May 14 12:56:14 PDT 2012
fork <forkandwait at ...> writes:
> Also, when I run the "query" from the right-click menu, and choose test, it
> gives me the number of rows without a select criteria (the above criteria
>should
> yield about 10 rows, but test says ~174000)
It seems that if I add a postgis layer with "estimate number of geometries
from statistics" or what it is called, the query functionality works again.
I could file a bug report if it seemed worthwhile.
Thoughts?
