> Hi Jake, > > If you are using a recent version (1.8 / trunk) - then you probably > hit a bug. Can you please report it? > > Otherwise I can really recommend to use SVG for more complex symbols. > > Andreas [JM] Hi Andreas Yes I use 1.7.4-Wrodaw revision 411aff6. I'll file a report. I like the SVG suggestion :) J
