[Qgis-user] Loading a Postgis Raster Layer
Andreas Neumann
a.neumann at carto.net
Tue May 15 05:19:10 PDT 2012
The standard Postgis loader dialogue cannot load raster. You need to
install a separate plugin to load Postgis raster. The plugin is called
wktraster: http://plugins.qgis.org/plugins/wktraster/
Hope this helps,
Andreas
On Tue, 15 May 2012 08:14:46 +0000, giannis Nj wrote:
> Hi to all,
> I try to Add a raster layer from the Postgis 2.0. I connect normally
> to the database and I load and display shapefiles correctly, but my
> raster data tables appears to have no geometry and they can't be
> displayed in QGIS. Has anyone managed to display normally raster data
> from Postgis, in order to help me out? Thanks.
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
