[Qgis-user] Batch conversion of rasters
Rudi Thiede rudi at linfiniti.com
Thu May 17 06:16:55 PDT 2012
If I understand your problem correctly ...
The classification of a raster in the display is not related to the file
itself, but to the layer as you see it in the display. Even if you load the
original .asc file as a new layer, it won't have the correct colors. It's
not a problem of image format conversion.
So the only way I can think of to solve your problem is to save the style,
then apply it to the new .tiff image later. Maybe save the style to be the
same as the file name (sans extension) of the image you're converting, so
that you know which image to apply it to (if they're not all the same). I'm
not sure how to do this automatically though, so if you have 500 images
you're going to hate me ...
On 17 May 2012 10:52, giannis Nj <netsagief at hotmail.com> wrote:
> I want to convert a directory with .asc files to .tiffs, but I need the
> output files to have the same colour analysis, as when they are already
> loaded in qgis display. I try Raster->Conversion->Translate (Convert
> format) but it gives each file with different colours. Is there any other
> way to make it? Maybe a batch convert somehow after the files are loaded on
> screen?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120517/d557b228/attachment.html>
