[Qgis-user] batch shapefile reproject?
Nick Ves vesnikos at gmail.com
Sat May 19 16:06:59 PDT 2012
I think that macos have their native bash interpreter (aka the TERMINAL).
if so a simple
for file in `ls *.shp` ; do ogr2ogr <ogr2ogr-commands> $file; done
should do the trick. Just run it from the terminal inside the folder you
have your shapes, or write it down to a file, make it executable (chmod +x
the-script.sh) and run it (double click?)
 The above might need some fine-tuning thats the general idea :)
happy scripting
Nick Ves
On Sat, May 19, 2012 at 11:53 AM, gvSIGMac <gvsig.mac at gmail.com> wrote:
> If you got Qgis from
> www.kyngchaos.com
> you already have ogr2ogr in your system thru gdal
> http://www.kyngchaos.com/software/frameworks
> You only need to set your path or run
> /Library/Frameworks/GDAL.framework/Versions/Current/Programs/ogr2ogr
> ________________________________
> Agustin
> On 18/05/2012, at 20:23, Chris Henrick <chrishenrick at gmail.com> wrote:
> Thanks for the pointer David, I appreciate it.
> I'm using QGIS 1.7.4 on Mac OSX 10.6.8, so I can run ogr2ogr in linux. I'm
> not too familiar with running code in terminal, but a friend recomended
> installing home brew and xcode first. Do you know of any helpful tutorials
> to help a newby get started with running open source command line code?
> regards,
> -Chris
> On Fri, May 18, 2012 at 11:12 AM, David J. Bakeman <dbakeman at comcast.net>wrote:
>> Chris Henrick wrote:
>> Hi there,
>>  Does anyone have a python script or know of a 3rd party plug in that
>> will allow a directory of shapefiles to be reprojected into a specified
>> CRS? Would also be helpful to do the same with the clip tool
>> You didn't say what OS so your mileage may vary.  For this kind of
>> operation I would use the ogr2ogr application from the gdal utilities.  I
>> believe if you're using the windows osgeo install that it is installed if
>> you're using linux it's a matter of installing gdal which if you have qgis
>> it's probably already there.
>> So to reproject a bunch of shapefiles the source files in d0 and the
>> destination in d1:
>> ogr2ogr -t_srs (specify the target CRS you can use proj4 string or an
>> existing .prj file) d1 d0
>> The default type for ogr2ogr is shapefile so you don't need to specify a
>> type even.  ogr2ogr also does other operations including clipping.
>>  I'm a fairly novice programmer so any advice would be appreciated.
>>  thanks,
>> -Chris
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120520/9a6c70a7/attachment.html>
