[Qgis-user] batch shapefile reproject?
    gvSIGMac
    gvsig.mac at gmail.com
    Sat May 19 01:53:52 PDT 2012
If you got Qgis from
www.kyngchaos.com
you already have ogr2ogr in your system thru gdal
http://www.kyngchaos.com/software/frameworks
You only need to set your path or run
/Library/Frameworks/GDAL.framework/Versions/Current/Programs/ogr2ogr
Agustin
On 18/05/2012, at 20:23, Chris Henrick <chrishenrick at gmail.com> wrote:
> Thanks for the pointer David, I appreciate it.
> I'm using QGIS 1.7.4 on Mac OSX 10.6.8, so I can run ogr2ogr in linux. I'm not too familiar with running code in terminal, but a friend recomended installing home brew and xcode first. Do you know of any helpful tutorials to help a newby get started with running open source command line code?
> regards,
> -Chris
> On Fri, May 18, 2012 at 11:12 AM, David J. Bakeman <dbakeman at comcast.net> wrote:
> Chris Henrick wrote:
>> Hi there,
>> Does anyone have a python script or know of a 3rd party plug in that will allow a directory of shapefiles to be reprojected into a specified CRS? Would also be helpful to do the same with the clip tool
> You didn't say what OS so your mileage may vary.  For this kind of operation I would use the ogr2ogr application from the gdal utilities.  I believe if you're using the windows osgeo install that it is installed if you're using linux it's a matter of installing gdal which if you have qgis it's probably already there.
> So to reproject a bunch of shapefiles the source files in d0 and the destination in d1:
> ogr2ogr -t_srs (specify the target CRS you can use proj4 string or an existing .prj file) d1 d0
> The default type for ogr2ogr is shapefile so you don't need to specify a type even.  ogr2ogr also does other operations including clipping.
>> I'm a fairly novice programmer so any advice would be appreciated.
>> thanks,
>> -Chris
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120519/54bf1eb7/attachment.html>
