[Qgis-user] Qgis crashes frequently when digitizing streams over WMS images
Filipe Silva Dias
filipesdias at gmail.com
Sun May 20 12:17:03 PDT 2012
I did some more tests in 2 PCs
With tiff - on a new and clean project (opened, loaded .tiff and shp and
started digitizing), this problem doesnt seem to occur, or at least is a
lot less frequent.
With WMS - it depends, sometimes I dont get any crashes for 2/3 hours, and
on other occasions I get crash after crash.
If indeed Im the only user affected by this, Ill switch to another software
and be done with it.
Thanks for your help
Best
On Sun, May 20, 2012 at 7:15 PM, Giovanni Manghi <
giovanni.manghi at faunalia.pt> wrote:
> On Sun, 2012-05-20 at 09:01 +0100, Filipe Silva Dias wrote:
> > Hi Giovanni.
> > Yes it happens on a different machine, with a clean installation. Did
> > you "push" things? Sometimes it only takes a few minutes to crash, but
> > on other ocasions it takes about 10 minutes (both with Bing images and
> > IGP images). Could it be related to the WMS server and with how QGIS
> > deals with any problems coming from the "other end"?
> I launched windows 7, qgis 1.8, added your data and added the wms
> overlays + other geotiff rasters. Started to edit and done everything I
> could think about (but not used 3rd party plugins... by the way, did you
> any 3rd party plugin before your tests?)... no crashes while adding,
> moving, merging, cutting, etc.
> cheers
> -- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120520/62f41550/attachment.html>
