[Qgis-user] Problemas with R and Python
Giovanni Manghi
giovanni.manghi at faunalia.pt
Mon May 21 01:32:53 PDT 2012
> recently i have a problem using tools depends R and Python, for
> example, SDA4PP. The problem in log file is:
> File "F:\ARQUIV~1\Quantum GIS
> Wroclaw\apps\Python27\lib\site-packages\rpy2\robjects\__init__.py",
> line 55, in
> conversion.ri2py = default_ri2py
> NameError: name 'conversion' is not defined
if nothing is changed recently, then the problem is that there is no
updated version of rpy2 for windows/python 2.7, so the bottom line is
that the support (under Windows) for the R based plugins is lost.
You may want to try an older QGIS version, still based on python 2.5.
cheers
-- Giovanni --
