[Qgis-user] Qgis crashes frequently when digitizing streams over WMS images
Filipe Silva Dias
filipesdias at gmail.com
Mon May 21 06:06:45 PDT 2012
Hi Giovanni
I think you already did more than enough to try to help determine what is
wrong with (my) QGIS. If Im the only one getting these crashes then its
safe to assume that there's something wrong "on my end".
I keep getting them in two machines and I have made numerous attempts to
understand what the hell is wrong with this. Maybe it is some specific
configuration parameter of QGIS, I dont know.
Fortunately for me there are other FOSS softwares I can use to do what I
need and If I ever get rid of these crashes and find out what was causing
them I will make sure to tell you.
Thanks again for help and efforts
Cheers
On Mon, May 21, 2012 at 1:36 PM, Giovanni Manghi <
giovanni.manghi at faunalia.pt> wrote:
> Hi Filipe,
> > With tiff - on a new and clean project (opened, loaded .tiff and shp
> > and started digitizing), this problem doesnt seem to occur, or at
> > least is a lot less frequent.
> > With WMS - it depends, sometimes I dont get any crashes for 2/3 hours,
> > and on other occasions I get crash after crash.
> > If indeed Im the only user affected by this, Ill switch to another
> > software and be done with it.
> Hi Filipe,
> I don't have any particular interest in confirming or not a bug. In this
> case I cannot confirm. I tested your data for 20/30 minutes and didn't
> get a crash. Last week I had to do a job that involved digitizing (using
> the same WMS layer you cite) and didn't get any crash in many hours of
> work.
> Does this mean that the issue is not confirmed? no... but as I tested on
> two OS including the one you use it is suspicious that can be a local
> problem. The only thing that does not convince me is that you get the
> crash on two different machines. Maybe the issue is caused by a specific
> QGIS configuration parameter?
> Would you be able to test in Linux, so it will be possible to get the
> eventual error message from the Linux console?
> cheers
> -- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120521/0e4e3c7d/attachment.html>
