[Qgis-user] Warp raster layer, huge files ouput
Etienne Tourigny etourigny.dev at gmail.com
Mon May 21 15:13:35 PDT 2012
you probably want to compress it, I assume your source is a geotiff
and it is compressed.
Gdaltools has options for this, you need to check out gdalwarp
compression options.  You'll need to add something like '-co
COMPRESS=DEFLATE' in the middle of the command.
Etiene
On Mon, May 21, 2012 at 6:56 PM, Marko Kvakić <markokvakic at gmail.com> wrote:
> Dear Qgis users,
> I am trying to change the projection on the Corine landuse raster dataset.
> The file in question is about 150 Mb, with the projection definition
> ETRS_1989_LAEA_L52_M10
> I have to change it into WGS84 one
> When running the Wrap plugin command, the resulting output file is 3 Gb big
> and unreadable.
> Any kind of help is very much appreciated.
> Thank you in advance.
> Marko Kvakić
> Qgis-user mailing list
