[Qgis-user] Warp raster layer, huge files ouput
Filipe Silva Dias filipesdias at gmail.com
Tue May 22 01:06:50 PDT 2012
Take a look at this.
http://linfiniti.com/2012/03/specifying-options-in-the-qgis-gdal-tools/
On Mon, May 21, 2012 at 11:13 PM, Etienne Tourigny
<etourigny.dev at gmail.com>wrote:
> you probably want to compress it, I assume your source is a geotiff
> and it is compressed.
> Gdaltools has options for this, you need to check out gdalwarp
> compression options.  You'll need to add something like '-co
> COMPRESS=DEFLATE' in the middle of the command.
> Etiene
> On Mon, May 21, 2012 at 6:56 PM, Marko Kvakić <markokvakic at gmail.com>
> wrote:
> > Dear Qgis users,
> > I am trying to change the projection on the Corine landuse raster
> dataset.
> > The file in question is about 150 Mb, with the projection definition
> > ETRS_1989_LAEA_L52_M10
> > I have to change it into WGS84 one
> > When running the Wrap plugin command, the resulting output file is 3 Gb
> big
> > and unreadable.
> > Any kind of help is very much appreciated.
> > Thank you in advance.
> > Marko Kvakić
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120522/163272ee/attachment.html>
