[Qgis-user] Problem with ManageR (python) - Mac
António Manuel Rodrigues
amrodrigues at fcsh.unl.pt
Fri May 25 02:04:02 PDT 2012
Using the latest versions of all frameworks from kyngchaos, when trying to run ManageR, I get:
An error has occured while executing Python code:
File "/Users/amrodrigues/.qgis/python/plugins/manageR/plugin.py", line 58, in run
from manageR import MainWindow, loadConfig, saveConfig
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 283, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/Users/amrodrigues/.qgis/python/plugins/manageR/manageR.py", line 68, in
import rpy2.robjects as robjects
File "/Library/Python/2.6/site-packages/rpy2/robjects/__init__.py", line 14, in
import rpy2.rinterface as rinterface
File "/Library/Python/2.6/site-packages/rpy2/rinterface/__init__.py", line 6, in
R_HOME = os.popen("R RHOME").readlines()
IOError: [Errno 4] Interrupted system call
Python version:
2.6.1 (r261:67515, Aug 2 2010, 20:10:18)
[GCC 4.2.1 (Apple Inc. build 5646)]
QGIS version:
1.7.4-Wroclaw Wroclaw,
Python path: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/amrodrigues/.qgis/python', '/Users/amrodrigues/.qgis/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.6', '/Library/Python/2.6/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.6/site-packages', '/Library/Python/2.6/site-packages/simplejson-2.1.5-py2.6-macosx-10.6-universal.egg', '/Library/Python/2.6/site-packages/setuptools-0.6c12dev_r88795-py2.6.egg', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload', '/Library/Python/2.6/site-packages', '/Library/Python/2.6/site-packages/PIL', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode', '~/.qgis/python', '/Users/amrodrigues/.qgis/python/plugins/fTools/tools', '/Users/amrodrigues/.qgis/python/plugins/openlayersov/logic', '/Users/amrodrigues/.qgis/python/plugins/openlayersov/gui']
Any help would be greatly appreciated.
Thank you,
António
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120525/3963fe48/attachment.html>
