[Qgis-user] Problem with ManageR (python) - Mac
William Kyngesburye
woklist at kyngchaos.com
Fri May 25 07:31:25 PDT 2012
Which version of R do you have?
I wonder if you installed Rpy2 for R 2.14, then upgraded to R 2.15. Then R 2.14 would be removed leaving Rpy2 binaries linking to nothing.
I have a new Rpy2 for R 2.15 now on my site.
On May 25, 2012, at 4:04 AM, António Manuel Rodrigues wrote:
> Hi,
> Using the latest versions of all frameworks from kyngchaos, when trying to run ManageR, I get:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/Users/amrodrigues/.qgis/python/plugins/manageR/plugin.py", line 58, in run
> from manageR import MainWindow, loadConfig, saveConfig
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 283, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/Users/amrodrigues/.qgis/python/plugins/manageR/manageR.py", line 68, in
> import rpy2.robjects as robjects
> File "/Library/Python/2.6/site-packages/rpy2/robjects/__init__.py", line 14, in
> import rpy2.rinterface as rinterface
> File "/Library/Python/2.6/site-packages/rpy2/rinterface/__init__.py", line 6, in
> R_HOME = os.popen("R RHOME").readlines()
> IOError: [Errno 4] Interrupted system call
> Python version:
> 2.6.1 (r261:67515, Aug 2 2010, 20:10:18)
> [GCC 4.2.1 (Apple Inc. build 5646)]
> QGIS version:
> 1.7.4-Wroclaw Wroclaw,
> Python path: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/amrodrigues/.qgis/python', '/Users/amrodrigues/.qgis/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.6', '/Library/Python/2.6/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.6/site-packages', '/Library/Python/2.6/site-packages/simplejson-2.1.5-py2.6-macosx-10.6-universal.egg', '/Library/Python/2.6/site-packages/setuptools-0.6c12dev_r88795-py2.6.egg', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload', '/Library/Python/2.6/site-packages', '/Library/Python/2.6/site-packages/PIL', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode', '~/.qgis/python', '/Users/amrodrigues/.qgis/python/plugins/fTools/tools', '/Users/amrodrigues/.qgis/python/plugins/openlayersov/logic', '/Users/amrodrigues/.qgis/python/plugins/openlayersov/gui']
> Any help would be greatly appreciated.
> Thank you,
> António
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
