[Qgis-user] Qgis first startup is slow
Andreas Neumann a.neumann at carto.net
Sun May 27 02:47:43 PDT 2012
 the number are ok in my opinion. I assume you don't have an SSD disk,
 so times will be a bit slower than with a modern PC with SSD. Then 20
 plugins activated are kind of a lot. I usually have fewer plugins
 activated. You also see that 30s out of the 50s are spent on loading the
 plugins. So if you want to speed up QGIS start you better deactivate
 some plugins you don't need.
 So to me it seems like there are no immediate actions needed from the
 QGIS team because of slow startup.
 The other fact, that repeated loading of programs are faster than the
 first after a boot - this seems normal to me and I observe this with a
 lot of other software (e.g. Adobe software) as well. It is probably
 related that some base libraries are already active or loaded.
 Andreas
 On Fri, 25 May 2012 05:47:11 -0700 (PDT), haubourg wrote:
> Here are the results of a small bench:
> Qgis 1.7.4 Standalone. Windows server 2003 + citrix XenAPP. It is on
> virtualized shared servers, though I don't know if servers are really
> busy
> or not.
> 1- Qgis with 20 plugins activated:
>   First startup takes about 50 seconds, and different steps are
> linear (30 s
> to restore python plugins)
>   Second startup  takes about 15 seconds, and still seems linear.
> 2- Qgis with *no* plugin activated.
>   First startup takes 20 s
>   Second startup takes less than 4s
> New behaviour observed today (to be confirmed). I started Qgis and
> let it
> inactive for two hours at lunch. I came back, quit Qgis, and startup
> is
> again slow. I start up again and it is fast again.. So, I guess there
> is no
> relation with session initializing.
> I'm going to check what's happening with virtual machine underneath..
> Régis
> http://osgeo-org.1560.n6.nabble.com/Qgis-first-startup-is-slow-tp4975911p4976931.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
