[Qgis-user] Rotate feature
Giovanni Manghi giovanni.manghi at faunalia.pt
Tue May 29 06:45:02 PDT 2012
On Tue, 2012-05-29 at 15:04 +0300, Micha Silver wrote:
> On 29/05/2012 14:23, Agustin Lobo wrote:
> > Is it possible to rotate a grop of selected points
> > in a similar way as it is done with "move feature"?
> If you want to use spatialite, have a look at:
> http://www.faunalia.com/content/geoprocess-geometries-within-your-database-spatialite-example
> Also PostGIS has a full featured ST_Rotate() function.
yes it can be done inside the DB but I guess that for most of the users
having such tool in the editing toolbar would be great.
I recently had to do some digitizing work (starting from an already
existing work) to do a land use map and I also felt the lack of tools
like:
* fill hole/fill space (space between polygons)
* add ring+automatic fill
* a tool to help remove overlapped areas
Just in case I already filed tickets with feature requests.
cheers
-- Giovanni --
