[Qgis-user] Rotate feature
Agustin Lobo alobolistas at gmail.com
Tue May 29 10:48:56 PDT 2012
Yes, I was looking for an interactive tool, similar to the "move feature".
But the method using spatialite is very interesting, thanks for leting me know.
I now have more or less a certain pattern of points with the centers of
the aerial pictures to be acquired, and it would be easier just moving
and rotating the
pattern to fit different study areas than generating the points from
scratch again.
Giovanni, can you post the link to your ticket? Also, I recall something
on a place with general suggestions for editing tools, but cannot
actually find it.
Agus
2012/5/29 Giovanni Manghi <giovanni.manghi at faunalia.pt>:
> Hi,
> On Tue, 2012-05-29 at 15:04 +0300, Micha Silver wrote:
>> On 29/05/2012 14:23, Agustin Lobo wrote:
>> > Is it possible to rotate a grop of selected points
>> > in a similar way as it is done with "move feature"?
>> If you want to use spatialite, have a look at:
>> http://www.faunalia.com/content/geoprocess-geometries-within-your-database-spatialite-example
>> Also PostGIS has a full featured ST_Rotate() function.
> yes it can be done inside the DB but I guess that for most of the users
> having such tool in the editing toolbar would be great.
> I recently had to do some digitizing work (starting from an already
> existing work) to do a land use map and I also felt the lack of tools
> like:
> * fill hole/fill space (space between polygons)
> * add ring+automatic fill
> * a tool to help remove overlapped areas
> Just in case I already filed tickets with feature requests.
> cheers
> -- Giovanni --
> Qgis-user mailing list
