[Qgis-user] Rotate feature
Agustin Lobo
alobolistas at gmail.com
Wed May 30 10:12:55 PDT 2012
Yes, actually planning low-height aerial campaigns is very much
like planning field experiments. There is a need for both
non-interactive (which I do in R) and interactive tools.
Agus
2012/5/30 M.E.Dodd <m.e.dodd at open.ac.uk>:
> When designing field experiments having the ability to duplicate and rotate
> or move around a set of points or other features would be very useful.
> From: Micha Silver [mailto:micha at arava.co.il]
> Sent: 30 May 2012 08:41
> To: giovanni.manghi at faunalia.pt
> Cc: Agustin.Lobo at ictja.csic.es; qgis-user
> Subject: Re: [Qgis-user] Rotate feature
> On 29/05/2012 16:45, Giovanni Manghi wrote:
> Hi,
> On Tue, 2012-05-29 at 15:04 +0300, Micha Silver wrote:
> On 29/05/2012 14:23, Agustin Lobo wrote:
> Is it possible to rotate a grop of selected points
> in a similar way as it is done with "move feature"?
> If you want to use spatialite, have a look at:
> http://www.faunalia.com/content/geoprocess-geometries-within-your-database-spatialite-example
> Also PostGIS has a full featured ST_Rotate() function.
> Hi Giovanni
> Thanks for the response.
> yes it can be done inside the DB but I guess that for most of the users
> having such tool in the editing toolbar would be great.
> I recently had to do some digitizing work (starting from an already
> existing work) to do a land use map and I also felt the lack of tools
> like:
> * fill hole/fill space (space between polygons)
> * add ring+automatic fill
> * a tool to help remove overlapped areas
> These are all probably more useful (or "in demand") than a tool to rotate a
> features. I thought this specific case that Agus brought up would be quite
> rare in general geoprocessing, so it's good to see there is a procedure that
> can handle it, even tho' it's not a one-click GUI tools.
> Just in case I already filed tickets with feature requests.
> cheers
> -- Giovanni --
> This mail was received via Mail-SeCure System.
> Micha Silver
> 052-3665918
> The Open University is incorporated by Royal Charter (RC 000391), an exempt
> charity in England & Wales and a charity registered in Scotland (SC 038302).
> Qgis-user mailing list
