[Qgis-user] Rotate feature
Agustin Lobo
alobolistas at gmail.com
Wed May 30 10:18:52 PDT 2012
Thanks, I certainly will try it for this application.
Agus
2012/5/30 Robert Nuske <rnuske at gwdg.de>:
> Am Mittwoch, 30. Mai 2012, 08:49:12 schrieb M. E. Dodd:
>> When designing field experiments having the ability to duplicate and rotate
>> or move around a set of points or other features would be very useful.
> OpenJump ( http://openjump.org ) has these nice features (rotate, move, resize
> etc) handy in its Editing-Tools.
> I am not a regular OpneJump user, but used these tools happily to rotate and
> shift a set of polygons.
> cheers,
> robert
>> From: Micha Silver [mailto:micha at arava.co.il]
>> Sent: 30 May 2012 08:41
>> To: giovanni.manghi at faunalia.pt
>> Cc: Agustin.Lobo at ictja.csic.es; qgis-user
>> Subject: Re: [Qgis-user] Rotate feature
>> On 29/05/2012 16:45, Giovanni Manghi wrote:
>> Hi,
>> On Tue, 2012-05-29 at 15:04 +0300, Micha Silver wrote:
>> On 29/05/2012 14:23, Agustin Lobo wrote:
>> Is it possible to rotate a grop of selected points
>> in a similar way as it is done with "move feature"?
>> If you want to use spatialite, have a look at:
>> http://www.faunalia.com/content/geoprocess-geometries-within-your-database-s
>> patialite-example
>> Also PostGIS has a full featured ST_Rotate() function.
>> Hi Giovanni
>> Thanks for the response.
>> yes it can be done inside the DB but I guess that for most of the users
>> having such tool in the editing toolbar would be great.
>> I recently had to do some digitizing work (starting from an already
>> existing work) to do a land use map and I also felt the lack of tools
>> like:
>> * fill hole/fill space (space between polygons)
>> * add ring+automatic fill
>> * a tool to help remove overlapped areas
>> These are all probably more useful (or "in demand") than a tool to rotate a
>> features. I thought this specific case that Agus brought up would be quite
>> rare in general geoprocessing, so it's good to see there is a procedure
>> that can handle it, even tho' it's not a one-click GUI tools.
>> Just in case I already filed tickets with feature requests.
>> cheers
>> -- Giovanni --
>> This mail was received via Mail-SeCure System.
>> Micha Silver
>> 052-3665918
> Robert Nuske
> Department of Ecoinformatics,
> Biometrics & Forest Growth
> Buesgenweg 4
> 37077 Goettingen
> GERMANY
> Phone: +49-551-39-22362
> Fax : +49-551-39-3465
> Qgis-user mailing list
