[Qgis-user] Using/visualizing 3D data (Z values)
swapneswar dehury swapneswar.com at gmail.com
Tue Oct 16 10:59:27 PDT 2012
Dear all
    I am a new QGIS user ,want to upload all my shape iles in my
personal web.some one please inform me the process
thanks
On 10/16/12, gene <martin.laloux at gmail.com> wrote:
> Waiting for Globe, a solution to extract the z values of 3D shapefiles is to
> use ogr or shapely (see in qgis-developer
> http://osgeo-org.1560.n6.nabble.com/Re-Qgis-user-Using-visualizing-3D-data-Z-values-td5004272.html
> <http://osgeo-org.1560.n6.nabble.com/Re-Qgis-user-Using-visualizing-3D-data-Z-values-td5004272.html>
> http://osgeo-org.1560.n6.nabble.com/visualizing-3D-data-Z-values-or-data-with-z-attribute-a-solution-td5005360.html
> <http://osgeo-org.1560.n6.nabble.com/visualizing-3D-data-Z-values-or-data-with-z-attribute-a-solution-td5005360.html>
> After  you can use matplotlib or other Python modules like  * Visvis
> <http://code.google.com/p/visvis/>  * to visualize the data in 3D:
> <http://osgeo-org.1560.n6.nabble.com/file/n5009086/qgisvisvissurfbok.png>
> (see also, with  http://code.google.com/p/visvis/wiki/Screenshots
> <http://code.google.com/p/visvis/wiki/Screenshots>  )
> This solution also applies to layers with z attribute.
> The full explanation of the processing is given, in French, at  QGIS,
> représentation 3D des couches vectorielles (shapefiles dits 3D ou shapefiles
> avec attributs z) avec avec les modules Python Matplotlib ou Visvis à partir
> de la console Python
> <http://www.portailsig.org/content/qgis-representation-3d-des-couches-vectorielles-shapefiles-dits-3d-ou-shapefiles-avec-attrib>
> http://osgeo-org.1560.n6.nabble.com/Using-visualizing-3D-data-Z-values-tp4126375p5009086.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
*SWAPNESWAR DEHURY
PG.DIPLOMA GIS & RS (U.U)
GIS TECHNICIAN*
mob 9237212764
