[Qgis-user] Using/visualizing 3D data (Z values)
David Fawcett
david.fawcett at gmail.com
Tue Oct 16 19:39:29 PDT 2012
Gene,
Your email and posts got me inspired to install visvis.
I am running Qgis 1.8 on OSX using William's installers at
kyngchaos.com. By default, I don't have a GUI toolkit installed for
the backend. Does anyone have any suggestions on the best way to get
one installed without conflicting with QGIS or other applications?
Thanks,
David.
On Tue, Oct 16, 2012 at 12:27 PM, gene <martin.laloux at gmail.com> wrote:
> Waiting for Globe, a solution to extract the z values of 3D shapefiles is to
> use ogr or shapely (see in qgis-developer
> http://osgeo-org.1560.n6.nabble.com/Re-Qgis-user-Using-visualizing-3D-data-Z-values-td5004272.html
> <http://osgeo-org.1560.n6.nabble.com/Re-Qgis-user-Using-visualizing-3D-data-Z-values-td5004272.html>
> http://osgeo-org.1560.n6.nabble.com/visualizing-3D-data-Z-values-or-data-with-z-attribute-a-solution-td5005360.html
> <http://osgeo-org.1560.n6.nabble.com/visualizing-3D-data-Z-values-or-data-with-z-attribute-a-solution-td5005360.html>
> After you can use matplotlib or other Python modules like * Visvis
> <http://code.google.com/p/visvis/> * to visualize the data in 3D:
> <http://osgeo-org.1560.n6.nabble.com/file/n5009086/qgisvisvissurfbok.png>
> (see also, with http://code.google.com/p/visvis/wiki/Screenshots
> <http://code.google.com/p/visvis/wiki/Screenshots> )
> This solution also applies to layers with z attribute.
> The full explanation of the processing is given, in French, at QGIS,
> représentation 3D des couches vectorielles (shapefiles dits 3D ou shapefiles
> avec attributs z) avec avec les modules Python Matplotlib ou Visvis à partir
> de la console Python
> <http://www.portailsig.org/content/qgis-representation-3d-des-couches-vectorielles-shapefiles-dits-3d-ou-shapefiles-avec-attrib>
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Using-visualizing-3D-data-Z-values-tp4126375p5009086.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
