[Qgis-user] How to open a file geodatabase?
Admin moges_mamo at shaw.ca
Wed Oct 17 21:26:51 PDT 2012
Hi there,
Will you remove me from the list for a time being please
Thanks
Moges
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Luke
Sent: October 17, 2012 9:07 PM
To: Matt Boyd
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] How to open a file geodatabase?
Hi
If you goto Settings\Options\GDAL you will see a list of formats your
version of QGIS can currently open
If you install QGIS via OSGeo4W you can add the ESRI FileGDB API option
Also remember you can only open FGDB which are v.10 (or above? not sure)
Regards,
Luke B
On Thu, Oct 18, 2012 at 12:36 PM, Matt Boyd <mattslists at gmail.com> wrote:
On Thu, Oct 18, 2012 at 4:24 AM, boesiii <boesiii at yahoo.com> wrote:
> I installed the additional gdal file but when I try to pick the layer to
add
> Qgis freezes up and closes.
I vaguely remember checking the open directory button in the dialogue
box for adding a file database (rather than opening he gdb file in
that directory specifically). You could also try browsing to it using
QGIS explorer then drag and drop on the map, it should recognise it if
GDAL is working as it should. This may be obvious, but it wasn't at
the time for me.
Matt
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Luke Bassett
Melbourne Australia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121017/95b9189b/attachment.html>
