[Qgis-user] WMTS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Aug 1 03:42:50 PDT 2013
Hi List,
How do I use WMTS in QGIS (weekly build)?
I've tried searches on:
- qgis.org - no results
- wiki - no results
- http://docs.qgis.org/2.0/html/en/docs/user_manual - one results about
caches.
- plugs.qgis - no results
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130801/d0f7da16/attachment.html>
