[Qgis-user] WMTS
Andreas Neumann
a.neumann at carto.net
Fri Aug 2 02:29:39 PDT 2013
Hi Jonathan,
You just use the WMS connection dialogue. It also works for WMTS.
I am now opening a bug to change the "Add WMS layer" into "Add WMS/WMTS
layer". This should make things clearer to the users.
Andreas
On Thu, 1 Aug 2013 11:42:50 +0100, Jonathan Moules wrote:
> Hi List,
> How do I use WMTS in QGIS (weekly build)?
> I've tried searches on:
> * qgis.org [1] - no results
> * wiki - no results
> * http://docs.qgis.org/2.0/html/en/docs/user_manual [2] - one
> results
> about caches.
> * plugs.qgis - no results
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and
> may
> contain sensitive or protectively marked material up to RESTRICTED
> and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
> Links:
> [1] http://qgis.org
> [2] http://docs.qgis.org/2.0/html/en/docs/user_manual
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
