[Qgis-user] WMTS
Andreas Neumann
a.neumann at carto.net
Fri Aug 2 02:52:52 PDT 2013
And this is already fixed in Master - see
http://hub.qgis.org/issues/8396 - thanks to Jürgen.
Andreas
On Fri, 02 Aug 2013 11:29:39 +0200, Andreas Neumann wrote:
> Hi Jonathan,
> You just use the WMS connection dialogue. It also works for WMTS.
> I am now opening a bug to change the "Add WMS layer" into "Add
> WMS/WMTS layer". This should make things clearer to the users.
> Andreas
> On Thu, 1 Aug 2013 11:42:50 +0100, Jonathan Moules wrote:
>> Hi List,
>> How do I use WMTS in QGIS (weekly build)?
>> I've tried searches on:
>> * qgis.org [1] - no results
>> * wiki - no results
>> * http://docs.qgis.org/2.0/html/en/docs/user_manual [2] - one
>> results
>> about caches.
>> * plugs.qgis - no results
>> Thanks,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and
>> may
>> contain sensitive or protectively marked material up to RESTRICTED
>> and
>> should be handled accordingly. Unless you are the named addressee
>> (or
>> authorised to receive it for the addressee) you may not copy or use
>> it, or disclose it to anyone else. If you have received this
>> transmission in error please notify the sender immediately. All
>> email
>> traffic sent to or from us, including without limitation all GCSX
>> traffic, may be subject to recording and/or monitoring in accordance
>> with relevant legislation.
>> Links:
>> [1] http://qgis.org
>> [2] http://docs.qgis.org/2.0/html/en/docs/user_manual
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
