[Qgis-user] Docs about data based styles
Antonio Vico
avicomartin at gmail.com
Fri Aug 2 02:50:39 PDT 2013
Hi everyone,
Is there any doc about how to data based styles work (origins, positive
X-Y axes and rotation sign)?
In qgis master I am testing a marker style composing a vector field
marker (with X and Y attribute based on data) and a svg marker (with
angle and offset based on data) but I get incorrect results (I want a
vector field with a svg marker oriented at the end).
I tested vector field marker and svg offset (using the same values for
X,Y attibutes in vector field and X,Y offset in svg) but svg are not
coincident with end of vector field (it seem that possitive Y direction
is inverse for field marker and svg; changing sign in Y coordinates for
svg marker done good position for svg marker).
After this, I tested add angle to svg marker but now rotation in svg
marker is correct but not displacement and get bad result. I tested
different possibilities but I can't get good solution because I can't
understand the beaviour for rotation and displacement in svg marker.
Thanks in advance.
