[Qgis-user] WMTS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Aug 2 03:51:55 PDT 2013
Thanks Andreas;
I'd suggest changing the following text:
- Tooltip
- dialog header
- Help (may be changed, but my help doesn't load right now!)
Beyond that, it doesn't seem to work. I add my connection (
http://compass/geoserver/gwc/service/wmts), and then when I click "connect"
it swaps to the "server search" tab. But there's nothing listed. I didn't
tick any of the boxes.
GeoServer 2.3.4 WMTS.
ArcMap can connect to it, so I know it's not a problem with the WMTS.
How do I get it to work?
It does connect to my WMS fine.
Thanks,
Jonathan
On 2 August 2013 10:52, Andreas Neumann <a.neumann at carto.net> wrote:
> And this is already fixed in Master - see http://hub.qgis.org/issues/**
> 8396 <http://hub.qgis.org/issues/8396> - thanks to Jürgen.
> Andreas
> On Fri, 02 Aug 2013 11:29:39 +0200, Andreas Neumann wrote:
>> Hi Jonathan,
>> You just use the WMS connection dialogue. It also works for WMTS.
>> I am now opening a bug to change the "Add WMS layer" into "Add
>> WMS/WMTS layer". This should make things clearer to the users.
>> Andreas
>> On Thu, 1 Aug 2013 11:42:50 +0100, Jonathan Moules wrote:
>>> Hi List,
>>> How do I use WMTS in QGIS (weekly build)?
>>> I've tried searches on:
>>> * qgis.org [1] - no results
>>> * wiki - no results
>>> * http://docs.qgis.org/2.0/html/**en/docs/user_manual<http://docs.qgis.org/2.0/html/en/docs/user_manual>[2] - one
>>> results
>>> about caches.
>>> * plugs.qgis - no results
>>> Thanks,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and may
>>> contain sensitive or protectively marked material up to RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee (or
>>> authorised to receive it for the addressee) you may not copy or use
>>> it, or disclose it to anyone else. If you have received this
>>> transmission in error please notify the sender immediately. All email
>>> traffic sent to or from us, including without limitation all GCSX
>>> traffic, may be subject to recording and/or monitoring in accordance
>>> with relevant legislation.
>>> Links:
>>> [1] http://qgis.org
>>> [2] http://docs.qgis.org/2.0/html/**en/docs/user_manual<http://docs.qgis.org/2.0/html/en/docs/user_manual>
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130802/234f82c2/attachment.html>
