[Qgis-user] WMTS
Andreas Neumann
a.neumann at carto.net
Fri Aug 2 04:25:00 PDT 2013
Hi Jonathan,
Are you sure that the URL is correct? It seems that this server is only
available locally. At least it is not a publically available and correct
URL.
If you think there is a bug in QGIS, please write a bug report and
provide a test URL.
Andreas
On Fri, 2 Aug 2013 11:51:55 +0100, Jonathan Moules wrote:
> Thanks Andreas;
> I'd suggest changing the following text:
> - Tooltip
> - dialog header
> - Help (may be changed, but my help doesn't load right now!)
> Beyond that, it doesn't seem to work. I add my connection
> (http://compass/geoserver/gwc/service/wmts [8]), and then when I
> click
> "connect" it swaps to the "server search" tab. But there's nothing
> listed. I didn't tick any of the boxes.
> GeoServer 2.3.4 WMTS.
> ArcMap can connect to it, so I know it's not a problem with the WMTS.
> How do I get it to work?
> It does connect to my WMS fine.
> Thanks,
> Jonathan
> On 2 August 2013 10:52, Andreas Neumann wrote:
>> And this is already fixed in Master - see
>> http://hub.qgis.org/issues/8396 [5] - thanks to Jürgen.
>> Andreas
>> On Fri, 02 Aug 2013 11:29:39 +0200, Andreas Neumann wrote:
>>> Hi Jonathan,
>>> You just use the WMS connection dialogue. It also works for WMTS.
>>> I am now opening a bug to change the "Add WMS layer" into "Add
>>> WMS/WMTS layer". This should make things clearer to the users.
>>> Andreas
>>> On Thu, 1 Aug 2013 11:42:50 +0100, Jonathan Moules wrote:
>>>> Hi List,
>>>> How do I use WMTS in QGIS (weekly build)?
>>>> I've tried searches on:
>>>> * qgis.org [1] [1] - no results
>>>> * wiki - no results
>>>> * http://docs.qgis.org/2.0/html/en/docs/user_manual
>>>> [2] [2] - one
>>>> results
>>>> about caches.
>>>> * plugs.qgis - no results
>>>> Thanks,
>>>> Jonathan
>>>> This transmission is intended for the named addressee(s) only
>>>> and may
>>>> contain sensitive or protectively marked material up to
>>>> RESTRICTED and
>>>> should be handled accordingly. Unless you are the named
>>>> addressee (or
>>>> authorised to receive it for the addressee) you may not copy or
>>>> use
>>>> it, or disclose it to anyone else. If you have received this
>>>> transmission in error please notify the sender immediately. All
>>>> email
>>>> traffic sent to or from us, including without limitation all
>>>> GCSX
>>>> traffic, may be subject to recording and/or monitoring in
>>>> accordance
>>>> with relevant legislation.
>>>> Links:
>>>> [1] http://qgis.org [3]
>>>> [2] http://docs.qgis.org/2.0/html/en/docs/user_manual [4]
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org [6]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [7]
> This transmission is intended for the named addressee(s) only and
> may
> contain sensitive or protectively marked material up to RESTRICTED
> and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> Links:
> [1] http://qgis.org
> [3] http://qgis.org
> [4] http://docs.qgis.org/2.0/html/en/docs/user_manual
> [5] http://hub.qgis.org/issues/8396
> [6] mailto:Qgis-user at lists.osgeo.org
> [7] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [8] http://compass/geoserver/gwc/service/wmts
> [9] mailto:a.neumann at carto.net
Andreas Neumann
Switzerland
