[Qgis-user] WMTS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Aug 2 04:29:18 PDT 2013
Hi Andreas,
Yep, it's a local URL; that hostname is on our local DNS for our mapping
systems. The URL is correct; it works fine in ArcMap as noted.
My QGIS cannot connect to the internet so I can't test with external
datasets; QGIS's proxy setup doesn't like our proxy.
I held off reporting as a bug because I didn't know if I was doing
something wrong and there's no error.
Can other folks connect to a GeoServer WMTS?
Thanks,
Jonathan
On 2 August 2013 12:25, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Jonathan,
> Are you sure that the URL is correct? It seems that this server is only
> available locally. At least it is not a publically available and correct
> URL.
> If you think there is a bug in QGIS, please write a bug report and provide
> a test URL.
> Andreas
> On Fri, 2 Aug 2013 11:51:55 +0100, Jonathan Moules wrote:
>> Thanks Andreas;
>> I'd suggest changing the following text:
>> - Tooltip
>> - dialog header
>> - Help (may be changed, but my help doesn't load right now!)
>> Beyond that, it doesn't seem to work. I add my connection
>> (http://compass/geoserver/gwc/**service/wmts<http://compass/geoserver/gwc/service/wmts>[8]), and then when I click
>> "connect" it swaps to the "server search" tab. But there's nothing
>> listed. I didn't tick any of the boxes.
>> GeoServer 2.3.4 WMTS.
>> ArcMap can connect to it, so I know it's not a problem with the WMTS.
>> How do I get it to work?
>> It does connect to my WMS fine.
>> Thanks,
>> Jonathan
>> On 2 August 2013 10:52, Andreas Neumann wrote:
>> And this is already fixed in Master - see
>>> http://hub.qgis.org/issues/**8396 <http://hub.qgis.org/issues/8396> [5]
>>> - thanks to Jürgen.
>>> Andreas
>>> On Fri, 02 Aug 2013 11:29:39 +0200, Andreas Neumann wrote:
>>> Hi Jonathan,
>>>> You just use the WMS connection dialogue. It also works for WMTS.
>>>> I am now opening a bug to change the "Add WMS layer" into "Add
>>>> WMS/WMTS layer". This should make things clearer to the users.
>>>> Andreas
>>>> On Thu, 1 Aug 2013 11:42:50 +0100, Jonathan Moules wrote:
>>>> Hi List,
>>>>> How do I use WMTS in QGIS (weekly build)?
>>>>> I've tried searches on:
>>>>> * qgis.org [1] [1] - no results
>>>>> * wiki - no results
>>>>> * http://docs.qgis.org/2.0/html/**en/docs/user_manual<http://docs.qgis.org/2.0/html/en/docs/user_manual>
>>>>> [2] [2] - one
>>>>> results
>>>>> about caches.
>>>>> * plugs.qgis - no results
>>>>> Thanks,
>>>>> Jonathan
>>>>> This transmission is intended for the named addressee(s) only
>>>>> and may
>>>>> contain sensitive or protectively marked material up to
>>>>> RESTRICTED and
>>>>> should be handled accordingly. Unless you are the named
>>>>> addressee (or
>>>>> authorised to receive it for the addressee) you may not copy or
>>>>> use
>>>>> it, or disclose it to anyone else. If you have received this
>>>>> transmission in error please notify the sender immediately. All
>>>>> email
>>>>> traffic sent to or from us, including without limitation all
>>>>> GCSX
>>>>> traffic, may be subject to recording and/or monitoring in
>>>>> accordance
>>>>> with relevant legislation.
>>>>> Links:
>>>>> [1] http://qgis.org [3]
>>>>> [2] http://docs.qgis.org/2.0/html/**en/docs/user_manual<http://docs.qgis.org/2.0/html/en/docs/user_manual>[4]
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> ______________________________**_________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org [6]
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[7]
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use
>> transmission in error please notify the sender immediately. All email
>> traffic sent to or from us, including without limitation all GCSX
>> traffic, may be subject to recording and/or monitoring in accordance
>> Links:
>> [1] http://qgis.org
>> [3] http://qgis.org
>> [4] http://docs.qgis.org/2.0/html/**en/docs/user_manual<http://docs.qgis.org/2.0/html/en/docs/user_manual>
>> [5] http://hub.qgis.org/issues/**8396 <http://hub.qgis.org/issues/8396>
>> [6] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>> [7] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>> [8] http://compass/geoserver/gwc/**service/wmts<http://compass/geoserver/gwc/service/wmts>
>> [9] mailto:a.neumann at carto.net
> Andreas Neumann
> Switzerland
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130802/5a83538e/attachment.html>
