[Qgis-user] WMTS
Andreas Neumann a.neumann at carto.net
Fri Aug 2 05:12:13 PDT 2013
 Hi Jonathan,
 Perhaps it would make sense to go the extra mile and either test
 another Geoserver WMTS or make your WMTS server publically available (at
 least in a password protected manner) - so that people can test it.
 Although WMTS is standardized there are often minor issues that prevent
 particular implementations from working. I know that WMTS is working in
 general. I was able to test it against an Intergraph-based WMTS server -
 but I do not have a Geoserver instance at hand.
 Andreas
 On Fri, 2 Aug 2013 12:29:18 +0100, Jonathan Moules wrote:
> Hi Andreas,
> Yep, it's a local URL; that hostname is on our local DNS for our
> mapping systems. The URL is correct; it works fine in ArcMap as
> noted.
> My QGIS cannot connect to the internet so I can't test with external
> datasets; QGIS's proxy setup doesn't like our proxy.
> I held off reporting as a bug because I didn't know if I was doing
> something wrong and there's no error.
> Can other folks connect to a GeoServer WMTS?
> Thanks,
>  Jonathan
> On 2 August 2013 12:25, Andreas Neumann  wrote:
>> Hi Jonathan,
>> Are you sure that the URL is correct? It seems that this server is
>> only available locally. At least it is not a publically available
>> and correct URL.
>> If you think there is a bug in QGIS, please write a bug report and
>> provide a test URL.
>> Andreas
>> On Fri, 2 Aug 2013 11:51:55 +0100, Jonathan Moules wrote:
>>> Thanks Andreas;
>>> I'd suggest changing the following text:
>>> - Tooltip
>>> - dialog header
>>> - Help (may be changed, but my help doesn't load right now!)
>>> Beyond that, it doesn't seem to work. I add my connection
>>> (http://compass/geoserver/gwc/service/wmts [8] [8]), and then
>>> when I click
>>> "connect" it swaps to the "server search" tab. But there's
>>> nothing
>>> listed. I didn't tick any of the boxes.
>>> GeoServer 2.3.4 WMTS.
>>> ArcMap can connect to it, so I know it's not a problem with the
>>> WMTS.
>>> How do I get it to work?
>>> It does connect to my WMS fine.
>>> Thanks,
>>> Jonathan
>>> On 2 August 2013 10:52, Andreas Neumann  wrote:
>>>> And this is already fixed in Master - see
>>>> http://hub.qgis.org/issues/8396 [5] [5] - thanks to Jürgen.
>>>> Andreas
>>>> On Fri, 02 Aug 2013 11:29:39 +0200, Andreas Neumann wrote:
>>>>> Hi Jonathan,
>>>>> You just use the WMS connection dialogue. It also works for
>>>>> WMTS.
>>>>> I am now opening a bug to change the "Add WMS layer" into
>>>>> "Add
>>>>> WMS/WMTS layer". This should make things clearer to the
>>>>> users.
>>>>> Andreas
>>>>> On Thu, 1 Aug 2013 11:42:50 +0100, Jonathan Moules wrote:
>>>>>> Hi List,
>>>>>> How do I use WMTS in QGIS (weekly build)?
>>>>>> I've tried searches on:
>>>>>>         * qgis.org [1] [1] [1] - no results
>>>>>>         * wiki - no results
>>>>>> http://docs.qgis.org/2.0/html/en/docs/user_manual [2]
>>>>>> [2] [2] - one
>>>>>> results
>>>>>> about caches.
>>>>>>         * plugs.qgis - no results
>>>>>> Thanks,
>>>>>> Jonathan
>>>>>>  This transmission is intended for the named addressee(s)
>>>>>> only
>>>>>> and may
>>>>>> contain sensitive or protectively marked material up to
>>>>>> RESTRICTED and
>>>>>> should be handled accordingly. Unless you are the named
>>>>>> addressee (or
>>>>>> authorised to receive it for the addressee) you may not
>>>>>> copy or
>>>>>> use
>>>>>> it, or disclose it to anyone else. If you have received
>>>>>> this
>>>>>> transmission in error please notify the sender immediately.
>>>>>> All
>>>>>> email
>>>>>> traffic sent to or from us, including without limitation
>>>>>> all
>>>>>> GCSX
>>>>>> traffic, may be subject to recording and/or monitoring in
>>>>>> accordance
>>>>>> with relevant legislation.
>>>>>> Links:
>>>>>> [1] http://qgis.org [3] [3]
>>>>>> [2] http://docs.qgis.org/2.0/html/en/docs/user_manual [4]
>>>>>> [4]
>>>> Andreas Neumann
>>>> Böschacherstrasse 10A
>>>> 8624 Grüt (Gossau ZH)
>>>> Switzerland
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org [6] [6]
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user [7] [7]
>>>  This transmission is intended for the named addressee(s) only
>>> and may
>>> RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee
>>> (or
>>> authorised to receive it for the addressee) you may not copy or
>>> use
>>> it, or disclose it to anyone else. If you have received this
>>> transmission in error please notify the sender immediately. All
>>> email
>>> traffic sent to or from us, including without limitation all GCSX
>>> accordance
>>> Links:
>>> [1] http://qgis.org [9]
>>> [2] http://docs.qgis.org/2.0/html/en/docs/user_manual [10]
>>> [3] http://qgis.org [11]
>>> [4] http://docs.qgis.org/2.0/html/en/docs/user_manual [12]
>>> [5] http://hub.qgis.org/issues/8396 [13]
>>> [6] mailto:Qgis-user at lists.osgeo.org [14]
>>> [7] http://lists.osgeo.org/mailman/listinfo/qgis-user [15]
>>> [8] http://compass/geoserver/gwc/service/wmts [16]
>>> [9] mailto:a.neumann at carto.net [17]
>> Andreas Neumann
>> Switzerland
>  This transmission is intended for the named addressee(s) only and
> may
> contain sensitive or protectively marked material up to RESTRICTED
> and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> transmission in error please notify the sender immediately. All email
> traffic, may be subject to recording and/or monitoring in accordance
> Links:
> [1] http://qgis.org
> [3] http://qgis.org
> [9] http://qgis.org
> [10] http://docs.qgis.org/2.0/html/en/docs/user_manual
> [11] http://qgis.org
> [12] http://docs.qgis.org/2.0/html/en/docs/user_manual
> [13] http://hub.qgis.org/issues/8396
> [14] mailto:Qgis-user at lists.osgeo.org
> [15] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [16] http://compass/geoserver/gwc/service/wmts
> [17] mailto:a.neumann at carto.net
> [18] mailto:a.neumann at carto.net
 Andreas Neumann
 Switzerland
