[Qgis-user] WMTS
    Andreas Neumann
    a.neumann at carto.net
    Fri Aug  2 04:31:21 PDT 2013
 The translation into any language is easy and possible for everyone,
 even if you don't know the language - you just add the /WMTS.
 Or are people translating the acronym WMS? Hopefully not.
 Andreas
 On Fri, 2 Aug 2013 12:38:54 +0200, Borys Jurgiel wrote:
> Hmmm, so now one of the most exposed actions will be untranslated...
> What about contacting active translating teams (those with >= 50%
> strings
> translated) and dealing manually with this string? Otherwise I'd vote
> for
> rolling back the commit... :(
> Dnia piątek, 2 sierpnia 2013 o 11:52:52 Andreas Neumann napisał(a):
>>  And this is already fixed in Master - see
>>  http://hub.qgis.org/issues/8396 - thanks to Jürgen.
>>  Andreas
>>  On Fri, 02 Aug 2013 11:29:39 +0200, Andreas Neumann wrote:
>> > Hi Jonathan,
>> > You just use the WMS connection dialogue. It also works for WMTS.
>> > I am now opening a bug to change the "Add WMS layer" into "Add
>> > WMS/WMTS layer". This should make things clearer to the users.
>> > Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
