[Qgis-user] WMTS
Borys Jurgiel
lists at borysjurgiel.pl
Fri Aug 2 05:37:53 PDT 2013
Dnia piątek, 2 sierpnia 2013 o 13:31:21 Andreas Neumann napisał(a):
> The translation into any language is easy and possible for everyone,
> even if you don't know the language - you just add the /WMTS.
> Or are people translating the acronym WMS? Hopefully not.
Ok, you're right. So just let's don't forget to replace it manually after the
last translation is accepted. Werner, will you remember? I can do it.
