[Qgis-user] transparency for QGIS backgroud color
Raymond Nijssen
r.nijssen at terglobo.nl
Sun Aug 4 04:18:21 PDT 2013
Hi Otto,
Unfortunately this is not possible. I could use this as well, making it
possible to put two map-items on top of each other in a composer.
Currently, in the options dialog, the "select color" (yellow) has a
color-dialog containing the alpha channel. The "background color" has a
dialog without it.
Raymond
On 31-07-13 17:52, Otto Dassau wrote:
> Hi,
> is it possible to set the background color in QGIS transparent. Can it be
> done in settings - project properties - backgroud color?
> Thanks
> Otto
> Qgis-user mailing list
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
