[Qgis-user] Cropping a raster with warp
Aaron Morris
amorris at bournemouth.ac.uk
Sun Aug 4 15:00:02 PDT 2013
Hi all,
Thanks for the help, however I have discovered a most simple solution, I think it may have been something to do with file permissions where I was saving the output, I changed this and the problem went away.
Many thanks again though.
________________________________________
From: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] On Behalf Of Alfonso Flaquer [alfonsofla220 at gmail.com]
Sent: 04 August 2013 22:47
To: Giacomo Marchioro
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Cropping a raster with warp
Hello
I'm not sure, but don't you have to transform your shape to a raster constant values before use it as a mask?
AfLa
El 04-08-2013, a las 16:23, Giacomo Marchioro <marchiorogiacomo at gmail.com<mailto:marchiorogiacomo at gmail.com>> escribió:
Have you tried to reproject again the data in the same CRS, Raster->Projections->Warp or/and save as Geotif? (I don't understand are you using Raster->Extraction->Clipper?)
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
