[Qgis-user] Print Composer Projects
Steven Campbell s.campbell at poole.gov.uk
Tue Aug 6 02:26:07 PDT 2013
Hi Alexandre
Thanks for your answer, but it doesn't quite answer what I'm after.
Basically I'm trying to find the folder location where the print
composer projects are being stored. When you create a new Print
Composer, it asks you for a name and then when you save it, it does so
but I don't know where! I'm trying to find out where QGIS saves these
print composer projects.
Thanks
Steve
From: Alexandre Neto [mailto:senhor.neto at gmail.com]
Sent: 05 August 2013 15:56
To: Steven Campbell
Cc: qgis-user
Subject: Re: [Qgis-user] Print Composer Projects
Hello Steve,
I'm Not sure if I understood your question... but here it goes.
Print composer "projects\layouts" are saved inside your QGIS Project
(*.QGS) file.
On the other hand, you can save a Print Composer as a Model (to use in
other projects), but in that case you will be asked for a saving
location. The same will happen if you decide to save\export your layout
as a PDF, image or SVG.
Hope it helped,
Alexandre Neto
On Mon, Aug 5, 2013 at 3:34 PM, Steven Campbell
<s.campbell at poole.gov.uk> wrote:
Can anyone tell me where the Print Composer projects are being stored?
I'm probably being stupid but I can't seem to identify where QGIS is
storing them (or at least I can't seem to find a way to specify where I
want to store a Print Composer Project!)
Thanks
Steve
Steve Campbell
GIS Manager
Corporate Strategy and Communications
Borough of Poole | Civic Centre | Poole BH15 2RU
Tel: 01202 633 362
Email: s.campbell at poole.gov.uk
Website:www.boroughofpoole.com <http://www.boroughofpoole.com/>
Think Green! Please Recycle
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130806/d6cc353a/attachment.html>
