[Qgis-user] combine field calculator functions
Michael Giebels
giebels at meo-carbon.com
Tue Aug 6 07:11:03 PDT 2013
Hi Carlos,
thanks for your input. I tried this before. However I am not able to
open *.dbf tables in Excel. It appears not to be readable in a suitable
form (Yes, I do go the way over right click, show all files, open, and
define seperators etc.). Somehow Excel does not read the row break
properly (when I try to import the pure data without the header it tries
to show all data in the first row and aborts due to limited number of
columns in Excel). I tried different file origins (MacIntosh, Windows,
DOS) as well. In a German forum I found information that Microsoft does
not support *.dbf files anymore for Excel 2010 or higher which might
explain that issue.
Btw: I am running QGIS 1.8 on a Mac OS X Version 10.7.5 (whom ever this
information helps) with MS Excel for Mac2011 Version 14.3.6 on it.
I mentioned it before to Nathan already. All I want to do in the end is
to convert six categories so I can display them in differing colors
without creating new layers. But that is the way I have to do it in the
end I guess.
Thanks for your replies and thanks for having me in the community
Michael
Am 06.08.13 15:24, schrieb Carlos Cerdán:
> ... or perhaps you can:
> 0. Add the new column, acording type od data and length and... save
> and close QGIS (no data added).
> 1. Open the *.DBF table with LibreOffice Calc or MS Excel, to take
> advantage of their functions
> 2. Calc-Excel formulas would be taken as text, so you have to
> overwrite them with their own results
> 3. Save (as *.DBF).
> 4. Open the shape in QGIS. It will have the new data.
> 5. An "advanced" step 2 is add new columns directly in Calc/Excel. For
> that, watch the headers: they have: name_of_camp , type_of_data , lenght
> Good luck
> Carlos Cerdán
> 2013/8/6 Nathan Woodrow <madmanwoo at gmail.com <mailto:madmanwoo at gmail.com>>
> Hey Micheal,
> This is currently not possible. If you are running QGIS 1.9 you
> do have the ability to define your own functions using Python
> example here
> https://github.com/NathanW2/qgsexpressionsplus/blob/master/functions.py however
> if you are new to Python and QGIS this isn't something I would do
> right away.
> - Nathan
> On Tue, Aug 6, 2013 at 9:38 PM, Michael Giebels
> <giebels at meo-carbon.com <mailto:giebels at meo-carbon.com>> wrote:
> Hello QGIS users,
> the QGIS world is new to me, so please be gentle...
> I am wondering how I could combine field calculator functions
> in order to convert information from an existing data column
> into a new one.
> What I can do with my mediocre knowledge is to query
> information from column 1 by setting
> "column1"='abc'
> which gives me a binary result (0,1) in my resulting column.
> Then I can
> replace ("newcolumn",'1','6')
> How could I combine these two into one working function (i.e.
> there MUST be a simple expression in the function list) and do
> not lose the new number when querying another information
> (e.g. 'cba') from column 1?
> Thanks in advance!
> Michael
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130806/3d8e6682/attachment.html>
