[Qgis-user] Problems installing nightly build on Mac OS X 10.6.8 (Snow Leopard)
Ramon AndiƱach
custard at westnet.com.au
Tue Aug 6 14:44:03 PDT 2013
Hi Julian,
This is almost certianly because the new musater is using some updated dependencies, as of mid april (see lower on the dakatocarto page in the changelog section). If you go to Kyngchaos.com and download and isntall the GDAL complete 1.10 package it should start working.
There may be a few other bits, e.g. if you're an ecw user, I don't think the ecw add-on to gdal is included in the complete package.
-ramon.
On 06/08/2013, at 22:28 , Julian Bogdani wrote:
> Hello all,
> I'm having problems getting QGIS nightly build run on MacOS X 10.6.8 (Snow Leopard).
> I downloaded the ZIP file qgis-mac-nightly_snoleo.zip from http://qgis.dakotacarto.com/ and installed it in the Application folder, but when I try to run it I get the following error: QGIS_2.0-dev_SnoLeo cannot be opened because of a problem. Check with the developer to make sure QGIS_2.0-dev_SnoLeo works with this version of Mac OS X.
> I had a old version of the 2.0 branch correctly running, but I erased it to install the most recent development version.
> I installed, removed and reinstalled everything10 days ago and today but I'm having the same problem.
> Is this a known issue? How can i get a working of the development build?
> Thank you
> Julian Bogdani
> jbogdani at gmail.com
> http://bradypus.net
> <Screen shot 2013-08-06 at 16.16.09 .png>_______________________________________________
> Qgis-user mailing list
