[Qgis-user] Problems installing nightly build on Mac OS X 10.6.8 (Snow Leopard)
Julian Bogdani
jbogdani at gmail.com
Wed Aug 7 00:15:59 PDT 2013
Reinstalling GDAL 1.10 and then QGIS 2.0 and then doing a cold reboot DID fix the problem. I can now correctly use the development version on Mac OS X 10.6.8.
Thank you all
Julian Bogdani
http://bradypus.net
On 6 Aug 2013, at 21:19 , Larry Shaffer wrote:
> Hi,
> I had no issues doing a fresh install of the latest nightly on Mac 10.7.5. QGIS had never been installed on that Mac before. Make sure you have the latest Kyngchaos.com frameworks installed (minimum for QGIS):
> GSL_Framework-1.15-2.dmg
> GDAL_Complete-1.10_2013-07-19.dmg
> If you want to use the GRASS tools inside QGIS (still uses GDAL_Complete-1.9):
> GDAL_Complete-1.9_2013-03-01.dmg
> FreeType_Framework-2.4.10-1.dmg
> cairo_Framework-1.12.2-1.dmg
> PIL-1.1.7-4.dmg
> GRASS-6.4.2-5-Snow.dmg
> GDAL_Complete-1.9 and 1.10 can be installed side-by-side without issue.
> If you still get an error please post details.
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> On Tue, Aug 6, 2013 at 12:30 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi Julian and Sergio,
> On Tue, Aug 6, 2013 at 9:04 AM, Sergio Zárate <acac09 at gmail.com> wrote:
> Hi all,
> had same problem today in Mountain Lion. Seems to be a GDAL issue. Will try to update GDAL an see if it solves the problem.
> If the dialog, noted by Julian, pops up again, please click the Show Details button and send the results to me directly (or link to a cleaned version here). Contacting me directly is the best means for addressing an issue with the nightly build(s), since I manage them and the Macs they are built on.
> I will test the builds on the machines today and see if I can reproduce the issue.
> I have noticed that OS X Qgis has been somewhat orphaned. In the past few months I have asked for solutions to problems but did not get any answers (had issues with Print Composer not displaying/printing GRASS rasters in Master).
> Sergio, QGIS for OS X is not at all orphaned. In fact, it has had lots of active development for the platform in the past 1.5 years. It just so happens that the current development cycle, 1.8 -> 2.0, is taking longer than previous version updates.
> Concerning your reported issues, it may be that your issues are difficult to fix, or maybe not even related to the Mac build. If you note which issues you are referring to, I can give you an opinion on maybe why they have not been addressed yet.
> Regards,
> Larry Shaffer
> Dakota Cartography
> Looking forward to the release of Master.
> Regards
> Sergio Zarate
> 2013/8/6 <qgis-user-request at lists.osgeo.org>
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Problems installing nightly build on Mac OS X 10.6.8 (Snow
> Leopard) (Julian Bogdani)
> Message: 1
> Date: Tue, 6 Aug 2013 16:28:18 +0200
> From: Julian Bogdani <jbogdani at gmail.com>
> To: qgis-user <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Problems installing nightly build on Mac OS X
> Message-ID: <6FBB34AF-C130-4912-B343-C1ACFC988BBF at gmail.com>
> Content-Type: text/plain; charset="us-ascii"
> Hello all,
> I'm having problems getting QGIS nightly build run on MacOS X 10.6.8 (Snow Leopard).
> I downloaded the ZIP file qgis-mac-nightly_snoleo.zip from http://qgis.dakotacarto.com/ and installed it in the Application folder, but when I try to run it I get the following error: QGIS_2.0-dev_SnoLeo cannot be opened because of a problem. Check with the developer to make sure QGIS_2.0-dev_SnoLeo works with this version of Mac OS X.
> I had a old version of the 2.0 branch correctly running, but I erased it to install the most recent development version.
> I installed, removed and reinstalled everything10 days ago and today but I'm having the same problem.
> Is this a known issue? How can i get a working of the development build?
> Thank you
> Julian Bogdani
> http://bradypus.net
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Name: Screen shot 2013-08-06 at 16.16.09 .png
> Type: image/png
> Desc: not available
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130806/045c373c/attachment.png>
> End of Qgis-user Digest, Vol 90, Issue 13
> Dr. Sergio Zárate Pedroche
> José María Arroyo 228
> Col. 22 de octubre
> Morelia, Michoacán
> C.P. 58341
> México
> Teléfono: (443) 352-5307
> Celular: (443) 438-6212
> http://independent.academia.edu/SergioZ%C3%A1ratePedroche
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130807/d0171877/attachment.html>
