[Qgis-user] OpenLayer plugin problem under PC named with Latin/special characters
Minoru Akagi
akaginch at gmail.com
Wed Aug 7 01:11:03 PDT 2013
Hi Milton,
There are two ways to avoid the problem:
1. Change the configuration folder path
You can change the configuration folder path with --configpath comandline
option. Python plugins are installed under the_folder\python\plugins.
Right-click the QGIS shortcut icon and open the property dialog. Then append
--configpath option to the link target as the following.
C:\OSGeo4W\bin\qgis.bat --configpath D:\ascii_path
2. Add a new user account
On the Windows control panel, you can add a new user account into your
Windows without formatting the OS.
Cheers,
Minoru
Milton Cezar Ribeiro wrote
> Dear all,
> Every computer that I tried to install OpenLayer plugin in which the
> computer´s name uses special characters like á è ã ç etc I got error. As
> many times one put its own name on the computers like JOÃO, TIÃO, JOSÉ,
> OpenLayer not work properly. I observed that this happens because
> Python-Qgis communication change Ã É etc for other strings, so the right
> path can´t be found.
> Any tips of how bypass this without format the windows and rename the
> machine?
> Best wishes
> Miltinho -
> mcr at .unesp
> Laboratório de Ecologia Espacial e Conservação - LEEC
> Depto de Ecologia - UNESP - Rio Claro
> Av. 24A, 1515- Bela Vista
> 13506-900 Rio Claro, SP, Brasil
> Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
> Cel: 19 9853-3220 / 19 9853-5430
> Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
> PG ECO & BIODIV
> http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
> CV
> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
> Qgis-user mailing list
> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/OpenLayer-plugin-problem-under-PC-named-with-Latin-special-characters-tp5071184p5071216.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
