[Qgis-user] OpenLayer plugin problem under PC named with Latin/special characters
Milton Ribeiro
miltinho.astronauta at gmail.com
Wed Aug 7 03:08:08 PDT 2013
Hil Minoru et al,
Thanks a lot for your suggestions. I will try this.
QGIS 2.0 is already available? Good to know.
best wishes
miltinho
2013/8/7 Minoru Akagi <akaginch at gmail.com>
> Hi Milton,
> There are two ways to avoid the problem:
> 1. Change the configuration folder path
> You can change the configuration folder path with --configpath comandline
> option. Python plugins are installed under the_folder\python\plugins.
> Right-click the QGIS shortcut icon and open the property dialog. Then
> append
> --configpath option to the link target as the following.
> C:\OSGeo4W\bin\qgis.bat --configpath D:\ascii_path
> 2. Add a new user account
> On the Windows control panel, you can add a new user account into your
> Windows without formatting the OS.
> Cheers,
> Minoru
> Milton Cezar Ribeiro wrote
> > Dear all,
> > Every computer that I tried to install OpenLayer plugin in which the
> > computer´s name uses special characters like á è ã ç etc I got error. As
> > many times one put its own name on the computers like JOÃO, TIÃO, JOSÉ,
> > OpenLayer not work properly. I observed that this happens because
> > Python-Qgis communication change Ã É etc for other strings, so the right
> > path can´t be found.
> > Any tips of how bypass this without format the windows and rename the
> > machine?
> > Best wishes
> > Miltinho -
> > mcr at .unesp
> > Laboratório de Ecologia Espacial e Conservação - LEEC
> > Depto de Ecologia - UNESP - Rio Claro
> > Av. 24A, 1515- Bela Vista
> > 13506-900 Rio Claro, SP, Brasil
> > Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
> > Cel: 19 9853-3220 / 19 9853-5430
> > Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
> > PG ECO & BIODIV
> > http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
> > CV
> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
> > Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
> > Qgis-user mailing list
> > Qgis-user at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> http://osgeo-org.1560.x6.nabble.com/OpenLayer-plugin-problem-under-PC-named-with-Latin-special-characters-tp5071184p5071216.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Miltinho - mcr at rc.unesp.br
PG ECO & BIODIV
CV
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130807/e5ded9f6/attachment.html>
