[Qgis-user] Label using $area and decimals
M. LATTES
ml at interatlas.fr
Thu Aug 8 00:59:31 PDT 2013
Hi Lene,
have you tried the "toint" and "tostring" function ?
This formula is to retrieve $area in square km with 2 decimal digit, but I
guess, you will adapt it for you :
tostring(toint($area/10000.0)/100.0) || ' km²'
Be warned that the "toint" make a round operation.
Regards.
Mathieu LATTES
Directeur Technique
m.lattes at interatlas.fr
http://www.interatlas.fr <http://www.interatlas.fr/>
http://www.urbimap.com <http://www.urbimap.com/>
De : qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] De la part de Lene Fischer
Envoyé : jeudi 8 août 2013 05:09
À : qgis-user at lists.osgeo.org
Objet : [Qgis-user] Label using $area and decimals
Hello
In Master I´m trying to set a label with the function $area. This works
fine.
But I´m trying to use the formatting for numbers with only 1 decimal - no
succes.
It works fine if I use a coloumn containing the area.
But this is not a solution because the $area is not dynamic in the coloum of
the attribut table.
Secondly - how do I activate the functions in the Labeltoolbar -ex Move or
Show/Hide
Regards
Lene Fischer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130808/2a80ea06/attachment.html>
