[Qgis-user] Spatial Join
Randal Hale
rjhale at northrivergeographic.com
Thu Aug 8 05:34:17 PDT 2013
Let me get to a good stopping point this morning and I'll test something
out. I think I might be able to say yes to the tool. I think.
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
<mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
On 08/08/2013 08:20 AM, Jonathan Moules wrote:
> Hi Randal,
> I had noticed the polygons to points converter, but wanted to do it
> "properly" - i.e. with a polygons in polygons comparison.
> Your method will likely work but adds two extra steps (conversion to
> points and then from points back to polygons). Does QGIS not have a
> tool for this then?
> Thanks!
> Jonathan
> On 8 August 2013 13:12, Randal Hale <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>> wrote:
> Here's how I would do it: You have Two polygon layers and you need
> to count the number of polygons in layer 1 that are contained in
> the polygons in layer 2
> 1. Convert the polygons in 1 to points: Vector -> geometry ->
> polygon centroids
> 2. then use -> vector -> analysis tools -> points in polygon.
> Count the number of points contained by polygons in layer 2.
> Hope that helps or at least creates an idea.
> Randy
> Randal Hale, GISP
> 423.653.3611 <tel:423.653.3611> rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com>
> <mailto:rjhale at northrivergeographic.com> <mailto:rjhale at northrivergeographic.com>
> twitter:rjhale
> On 08/08/2013 07:36 AM, Jonathan Moules wrote:
>> Hi List,
>> I have two layers of polygons. I want to do some analysis
>> between them, basically doing a spatial join, counting how many
>> of one polygon layer there are intersecting with each polygon in
>> the other layer.
>> ArcGIS does this easily with the "Spatial Join" tool (ArcToolbox
>> version). How can I do this in QGIS?
>> I know there is Vector -> Data Manage Tools -> Join attributes by
>> location, but that only acts as a basic join and doesn't allow
>> for counting of the number of joins.
>> Sextante has a large collection of tools, but none of them seem
>> to have any help so I don't know what any of them do. (And none
>> of them seem applicable anyway).
>> Suggestions welcome, Cheers,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and
>> may contain sensitive or protectively marked material up to
>> RESTRICTED and should be handled accordingly. Unless you are the
>> named addressee (or authorised to receive it for the addressee)
>> you may not copy or use it, or disclose it to anyone else. If you
>> have received this transmission in error please notify the sender
>> immediately. All email traffic sent to or from us, including
>> without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130808/ebae0972/attachment.html>
