[Qgis-user] Spatial Join
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Aug 8 05:37:58 PDT 2013
It's not temporally critical. I have ArcGIS and can (have) done it there;
this is more a learning exercise as to what QGIS can do and how to do
analysis with it. Spatially joining data like this is something I seem to
do quite often so I was surprised not to find a universal tool.
Cheers,
Jonathan
On 8 August 2013 13:34, Randal Hale <rjhale at northrivergeographic.com> wrote:
> Let me get to a good stopping point this morning and I'll test something
> out. I think I might be able to say yes to the tool. I think.
> Randal Hale, GISP
> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com<mailto:rjhale at northrivergeographic.com> <rjhale at northrivergeographic.com>
> twitter:rjhalehttp://about.me/rjhale
> On 08/08/2013 08:20 AM, Jonathan Moules wrote:
> Hi Randal,
> I had noticed the polygons to points converter, but wanted to do it
> "properly" - i.e. with a polygons in polygons comparison.
> Your method will likely work but adds two extra steps (conversion to
> points and then from points back to polygons). Does QGIS not have a tool
> for this then?
> Thanks!
> Jonathan
> On 8 August 2013 13:12, Randal Hale <rjhale at northrivergeographic.com>wrote:
>> Here's how I would do it: You have Two polygon layers and you need to
>> count the number of polygons in layer 1 that are contained in the polygons
>> in layer 2
>> 1. Convert the polygons in 1 to points: Vector -> geometry -> polygon
>> centroids
>> 2. then use -> vector -> analysis tools -> points in polygon. Count the
>> number of points contained by polygons in layer 2.
>> Hope that helps or at least creates an idea.
>> Randy
>> Randal Hale, GISP
>> On 08/08/2013 07:36 AM, Jonathan Moules wrote:
>> Hi List,
>> I have two layers of polygons. I want to do some analysis between
>> them, basically doing a spatial join, counting how many of one polygon
>> layer there are intersecting with each polygon in the other layer.
>> ArcGIS does this easily with the "Spatial Join" tool (ArcToolbox
>> version). How can I do this in QGIS?
>> I know there is Vector -> Data Manage Tools -> Join attributes by
>> location, but that only acts as a basic join and doesn't allow for counting
>> of the number of joins.
>> Sextante has a large collection of tools, but none of them seem to have
>> any help so I don't know what any of them do. (And none of them seem
>> applicable anyway).
>> Suggestions welcome, Cheers,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130808/957d6823/attachment.html>
